Total posts in this thread: 5
Previous Thread This topic has been viewed 995 times and has 4 replies Next Thread
cylinder mod?
Does anyone know if its possible to make the cylinder, available from the library, into a circle?
[Sep 18, 2018, 10:16:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: cylinder mod?
Ring is probably a better description than circle.
[Sep 18, 2018, 10:21:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: cylinder mod?
Mike,
The cylinder from the library is defined in three parts. If you make top and bottom invisible, you are left with a ring. Note that the wall thickness will be zero.
[Sep 22, 2018, 8:42:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: cylinder mod?
Thx for the reply Hans, not quite what i wanted, :-
cylinder 40mm diameter 1.2m long, then give it an arc 180 degrees (like a wall) and put 2 together - Ring.
Could not figure anything out with sh3d so i used sketchup.
It was to be used as a round edge on a worktop, the island in my last kitchen
thx again m8
[Sep 22, 2018, 10:54:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: cylinder mod?
Maybe put the idea of an arc for the box and cyl in wish list ????
[Sep 22, 2018, 10:56:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
