Total posts in this thread: 5
Previous Thread This topic has been viewed 2985 times and has 4 replies Next Thread
ilaria_123
Import room from .json
Hello,
I am new to the whole MVC paradigm and it's been a while since I've used Java. I am trying to write a plug-in where I can read a set of vertices from a .json file and draw a room with those vertices in SH3D (ideally I'd like to draw it in 2D and in 3D). It should be something extremely easy to do, so I've implemented the whole thing (I used the VolumePlugin example and I changed what happens in the execute() method) and it works up to the point where I try to actually add a wall (or a room) to the home. In fact, what happens is that the wall/room are simply not showed on the screen; the home stays empty. So I stripped the method out of everything else and simply added a couple of lines where I just add a wall to the home, and still I can't manage to see the new wall on the screen. This is the code I'm using:
Wall new_wall = new Wall(0.0, 0.0, 3.0, 0.0, 0.01, 2.5);
getHome().addWall(new_wall);
I read in the plug-in guide that because of the way the Plugin class has been implemented, all changes should be immediately reflected on the screen; however, now I'm thinking I'm missing something. Should I use HomeController or View or something else and refresh/redraw? I'm sorry if this is a dumb question but I spent the whole afternoon yesterday trying to figure it out and couldn't. Any help would be appreciated.
Thanks,
Ilaria
[Edit 1 times, last edit by Puybaret at Sep 26, 2018, 4:12:19 PM]
[Sep 26, 2018, 11:57:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Import room from .json
This should work but with the values you gave it will make a tiny wall, because the unit used in Sweet Home 3D is the centimeter.
[Sep 26, 2018, 4:14:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ilaria_123
It does indeed! I figured it out right after posting the thread, but for some reasons I couldn't see what I posted and couldn't delete it. Thanks for your answer anyway!
[Sep 27, 2018, 4:16:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Intrigued. Is this a private plugin or something you plan on sharing? It sounds as if it is a plugin that would be interesting to know more about. Good luck. ok
[Sep 28, 2018, 9:08:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ilaria_123
I am developing it for myself, but if someone is interested I can certainly share it :)
[Sep 28, 2018, 3:36:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
