Total posts in this thread: 5
Previous Thread This topic has been viewed 9358 times and has 4 replies Next Thread
benhur2407
Canada
3D view suddenly brigthens significantly
I am working on a house project. I added walls, rooms, doors and even a roof without problems. I was trying to add windows when the 3D view suddenly became significantly brighter, to the point where it is impossible to distinguish walls from ceiling when inside the house. I am currently using SH3D 5.2A. I tried updating to newer versions up to 5.7 but the problem occured again. I am on Windows 10-64 bit and my graphics card is AMD Radeon R290. The drivers of the graphics card have been kept up to date as well as Windows. My model size is currently 26 Mo only.
Is there a way to get rid of this annoying problem?
[Sep 27, 2018, 6:14:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
benhur2407
Canada
Re: 3D view suddenly brigthens significantly
Here is a link of screen captures before and after problem apperared:
Before: http://www.mediafire.com/view/1xj5k7to2uq2b6m/Before.png/file
After: http://www.mediafire.com/view/30rby7s75hwf9ui/After.JPG/file
Hope this helps.
[Sep 27, 2018, 8:14:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svedel77
+45 Denmark
Perhaps you have set the "Time of Day" differently in the render-settings?
[Sep 30, 2018, 3:11:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you try to reduce the light brightness in the 3D view modification pane shown by 3D view > Modify 3D view menu item?
[Sep 30, 2018, 6:32:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
benhur2407
Canada
This was happening while I was adding furniture (windows in this case) without changing anything else. I have tried using Integrated Graphics on my motherboard (Intel HD Graphics 4600) and the problem went away. I suspect my graphics card or its driver was the culprit even though the driver was the latest available and the graphics card was working perfectly with other software. For now, I will continue using Integrated Graphics but I'm afraid I'll lose performance when my model gets bigger. We'll see. Thanks for your replies.
[Oct 1, 2018, 5:08:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
