Total posts in this thread: 7
Previous Thread This topic has been viewed 4873 times and has 6 replies Next Thread
stef.salmon
Draw Round Column
This has probably been asked before...how can I draw a small circle to use as a column?
Why isn't there a tool to draw circles and ellipses?
Many thanks.
[Sep 28, 2018, 4:24:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ndorigatti
Italia
Re: Draw Round Column
You can use cylinder object!
[Sep 28, 2018, 4:47:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Cylinder object from where?
[Oct 4, 2018, 9:17:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
smile Re: Draw Round Column
It's a standard object made by Emmanuel ! wink
[Oct 4, 2018, 9:44:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
1 - draw two walls which start and end at the same coordinates.
2 - give one wall an arc of 180 degrees, the other of minus 180 degrees.
or look here
[Oct 4, 2018, 10:07:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The cylinder object can be found in the Miscellaneous category.
[Oct 4, 2018, 10:29:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Perfect...thank you all for your replies smile
[Oct 4, 2018, 10:57:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
