Total posts in this thread: 29
Posts: 29   Pages: 3   [ Previous Page | 1 2 3 ]
Previous Thread This topic has been viewed 20483 times and has 28 replies Next Thread
Re: massive color-difference
Not so sure this is a new topic, i seem to recall questioning it a couple of years ago, i have found that using textures is far more accurate than colors, here are 2 images, 1 a screenshot the other a render.
and this is a Q4 render
not only does the red change to pink but it also shows how different objects color differently, the I beams are rooms and the roller support brackets are box's, both have the same color applied to them.
[Nov 16, 2018, 10:49:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Well, more than 1 year after the last post, but... Has somebody tried to render one of these projects with YafaRay to see if the color difference between a pure color and a texture of the same color is still there?
[Dec 6, 2019, 8:05:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
Interesting idea. Yes, I have, but unfortunately I have changed all my projects from colored to textured objects.
But I will this give a try.
Pascal
[Dec 7, 2019, 11:26:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@UbuntuBirdy
This picture shows what's wrong in my opinion:
- The left cube has a texture which is only colored as #520015
- The right cube has the color #520015 directly
In my opinion both cubes should look the same, we should see exactly the same color. But only the textured cube shows the color #520015 as it should be.
I think the difference comes from the way Java 3D processes colors or textures.
Example of rendering in quality 1.
Enko
EnkoNyito
[Dec 13, 2019, 2:28:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Not sure if this issue has been attended to but i am still getting the same issue
Roof with colour:-
Roof with texture:-
[Feb 21, 2021, 11:24:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
This is a known "problem". Using an even-coloured texture is the solution, as you already found out.
[Feb 21, 2021, 11:40:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Just because it is something that is a "KNOWN PROBLEM" shouldn't mean we have to continue with "work arounds" rather than sorting the issues.
As a maintenance engineer i quite often use "work arounds" when needed to get a machine running, but, these are temporary, I return as soon as possible to properly make repair.
[Feb 21, 2021, 1:16:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
reddy.shyam
While we are at it, is my issue same as well? All my bright colors become pale when I generate an image. Please see attached.
Any setting I need to change while generating image?
Cannot attach any image host files for some reason. Tried imgur and prnt.sc`
[Feb 26, 2021, 6:47:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kutlu9
I'm having same problem as reddy.shyam. I was using the programm without any problems, suddenly my images become over exposed. Uninstall/reinstall didn't solved it.
I noticed sky texture or color doesn't render (rendering with only pure white color) making final image over exposed.
[Mar 14, 2021, 8:20:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
