Re: A small 2+ level apartment
Nice presentation Is it a terrace at the top right? I can see the toilets but where will you put a shower?
Italy
Thank you Emmanuel! Yes, it is a terrace, but I removed it almost completely in order to make visible the inside of the apartment. Here the small bath, with the bathtub.
There is a sliding door to enter it and, I know, the sink is small but it is intended to be a small apartment.
Italy
This tip proposes different ways. But I like the way you did.
Thank you, VeroniQ. I will try to use different ways to represent it, I need to finish the project of the home because it is still not complete. Then I will post the results :).
