Total posts in this thread: 5
Previous Thread This topic has been viewed 6129 times and has 4 replies Next Thread
bigjim33
raising existing walls and ceiling
hello to all,
I started to draw a project without noticing that the wall height is set to 250cm instead of 290cm. May I raise all the existing walls and the ceiling to 290cm at once?
thanks,
Marco
[Dec 5, 2018, 5:08:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: raising existing walls and ceiling
Hello Bigjim.
Select your whole design in Plan with Ctrl A (or cmd A on masOS), then Plan > Modify wall and change the height. Only your walls will be changed. If you have only one level, the ceiling will adjust itself at 290 cm. If you need a level, you can read this blog article .
[Dec 5, 2018, 7:26:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bigjim33
thank you!
[Dec 11, 2018, 2:35:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HananeBelyekdoumi
Canada
Is there a way to raise the walls in the online version of sweet home 3d? I was also wondering if there is a way to put a roof in the online version.
[Dec 20, 2020, 7:23:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The Online version isn’t finished, and you’ll have to be patient before these features become available. If you need them, I would suggest to export your online design and modify it with the installer version.
[Dec 20, 2020, 10:04:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
