+45 Denmark
PhotoVideoRendering-1.6 crashes
When rendering a movie using PhotoVideoRendering-1.6 plugin, SH3D crashes after a few minutes. No errorcode or description. It just crashes. This is if I render in 1920x1080 pixels. Rendering the same job in lower resolution, SH3d does not crash.
Rendering a movie with the built-in renderer, it's not a problem.
Re: PhotoVideoRendering-1.6 crashes
Soren,
Your image rendered without problems in 52 minutes. Memory usage was around 5-6 GB. Check Help -> About to see how much memory is available for SH3D on your computer. If necessary use the XMX-trick to increase memory.
