Previous Thread This topic has been viewed 5518 times and has 9 replies Next Thread
adrianoisoardi
italia
new version
I installed 5.7 version, but it doesn't start. Then I installed the last version 6.0, with the same result: it doesn't start. Someone can tell me what kind of problem could I have? (I have Java last version). Thanks.
Ho installato la versione 5.7 ma non parte. Lo stesso succede con la versione 6.0. Qualcuno sa dirmi che tipo di problema potrei avere? (La versione Java è l'ultima disponibile). Grazie.
[Dec 10, 2018, 8:19:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: new version
Which operating system do you use?
[Dec 11, 2018, 7:51:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
adrianoisoardi
italia
Re: new version
windows 7
[Dec 11, 2018, 7:56:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: new version
What do you mean by "it doesn't start"?
You get absolutely no message, just a double click on Sweet Home 3D icon then nothing...
[Dec 11, 2018, 10:33:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
adrianoisoardi
italia
Re: new version
After double click on the SH3D icon, the first image:
Sweet Home 3D
eTeks Copyrights 2007-2017 eTeks
Distribuited under GNU...
appears and remains fixed on desktop but the program doesn't start and
I can't remove it.
I tried to download and install new version many many times but nothing.
[Dec 11, 2018, 10:59:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Brynmawr
Re: new version
I think I can add to this problem :-
I have downloaded SweetHome3D-6.0 under Ubuntu 18.04, extracted the tar into my home directory and opened a terminal. I then ran :-
CD SweetHome3D-6.0
./SweetHome3D
This resulted in the SweetHome introductory window opening but then the following error messages in the terminal :-
Exception in thread "main" java.lang.InternalError: XXX0 profile[1]: GL3bc -> profileImpl GL4bc !!! not mapped
at com.jogamp.opengl.GLProfile.computeProfileMap(GLProfile.java:2071)
at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1924)
at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1875)
at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.java:1843)
at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80)
at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:230)
at java.security.AccessController.doPrivileged(Native Method)
at com.jogamp.opengl.GLProfile.initSingleton(GLProfile.java:216)
at com.jogamp.opengl.GLProfile.getProfileMap(GLProfile.java:2297)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1021)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050)
at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803)
at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131)
at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267)
at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:348
at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source)
Does this help and, if so, what can we do to correct the problem?
[Dec 31, 2018, 5:36:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DerekvG
Belgium
Re: new version
@brynmawr
I have the same problem :
SweetHome3D-6.0 under Ubuntu 18.04, extracted the tar into my .eteks/ directory and opened a terminal. I then ran :-
cd .eteks/SweetHome3D-6.0
./SweetHome3D
NO errromessages appeared
on dekstop the startup image is shown :
Sweet Home 3D
[Jan 3, 2019, 4:36:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: new version
Please try to run the alternate script SweetHome3D-Java3D-1_5_2 found in the same folder.
[Jan 3, 2019, 5:52:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Brynmawr
Re: new version
It gives the error message :-
Java 3D: implicit antialiasing enabled
Gtk-Message: 18:43:47.185: Failed to load module "canberra-gtk-module"
But SweetHome is up and, apparently, running. Thank you, I'll start climbing the learning curve :-)
[Jan 3, 2019, 6:46:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: new version
Great! The curve shouldn't be too steep wink
[Jan 8, 2019, 2:01:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
