Re: arch shape roofings
anybody can help for creating a arch shape roofing
Like ?
A little real picture would be welcomed… .
I suggest you can build your arch with walls in a new file, then import the arch as an objet with "Export to OBJ format" menu item. Take care to import only the walls.
You can’t bend a floor. And without a picture, it will be difficult to help you more, as alrealdy suggested.
Canada
There's no way to turn a wall from vertical to horizontal in SH3d .... the same as there's no way to bend a wall nor a roof to build a arch surface. If you know a better way to achieve such task, let us know since I'm not the only one asking that question.
Billmart, walls are vertical and can’t be leaned in Sweet Home 3D. By the way, please stop polluting other threads with similar questions. That won’t make appear this feature.
