Features
Total posts in this thread: 6
Previous Thread This topic has been viewed 618 times and has 5 replies Next Thread
sztui
Romania
Can you tell me what is wrong here?
Hello!
I kjust found this awesome software and i designed a weekend house that could be used for living as well.
I really loved working with this plan, but at the end something went wrong, some white bars appeared after i elevated levels.
It looks like the doors interfere with something.
Can you please tell me what is wrong?
You can download the plan here.
Thank you!
[Jan 21, 2019 11:33:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can you tell me what is wrong here?
I think if you replace the huge wall on the lowset level wit a triangle from the library you will be ok.
[Jan 21, 2019 1:29:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FDpaffie
Nederland
that is working. and lowering the wall where the house is standing on by 1 cm will help fixing the floor inside ,its coming trough the floor
[Jan 21, 2019 2:57:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    https://www.facebook.com/FDpaffie/photos/?tab=album&album_id=1257229600978115 [Link] Report threatening or abusive post: please login first  Go to top
sztui
Romania
Oh thank you guys!
It's working. Why is there difference between triangle wall and object triangle?
[Jan 22, 2019 1:16:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I noticed recently, in 2 of my projects, that when positioning a door or window above an angled wall there is a tendency for the "cutout" to drag the angled wall up. I did not know myself why this was but OKH came up with a good solution and Emmanuel explained it, i think that was happening for you.
[Jan 27, 2019 4:28:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Using the new version 6.1 would fix your issue too.
Doors and windows can make holes in walls, not in triangles. But until version 6.0, openings placed at an elevation between the bottom and the top of a sloping wall had also some parts under them like in your file (see thread #9104).
[Jan 28, 2019 11:06:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2019 eTeks - All rights reserved
