Romania
Can you tell me what is wrong here?
Hello!
I kjust found this awesome software and i designed a weekend house that could be used for living as well. I really loved working with this plan, but at the end something went wrong, some white bars appeared after i elevated levels. It looks like the doors interfere with something.
Nederland
Re: Can you tell me what is wrong here?
that is working. and lowering the wall where the house is standing on by 1 cm will help fixing the floor inside ,its coming trough the floor
I noticed recently, in 2 of my projects, that when positioning a door or window above an angled wall there is a tendency for the "cutout" to drag the angled wall up. I did not know myself why this was but OKH came up with a good solution and Emmanuel explained it, i think that was happening for you.
Using the new version 6.1 would fix your issue too.
Why is there difference between triangle wall and object triangle?
Doors and windows can make holes in walls, not in triangles. But until version 6.0, openings placed at an elevation between the bottom and the top of a sloping wall had also some parts under them like in your file (see thread #9104).
