+45 Denmark
PhotoVideoRendering-1.6 installation in Linux
I'm fairly new to Linux. I'm running Linux Mint. After installing SH3D via Synaptic, I can't find the plugins folder, to copy plugins to. What am I missing?
Re: PhotoVideoRendering-1.6 installation in Linux
I guess that Mint handles the same as Ubuntu (especially if you have the Ubuntu-based version). Then in your home directory there is a hidden folder called ".eteks". In this folder you will find another called "sweethome3d" and in it you will find the directory you are looking for: "plugins".
Pascal
If the folder "plugins" doesn't exist, create it yourself in ./eteks/sweethome3d. Then copy your plugins into that folder. When you start SH3D it will load the plugins it finds in that folder.
[Edit 1 times,
last edit by hansmex at Jan 27, 2019, 2:27:34 PM]
+45 Denmark
Thank you, that did the trick. But now SH3D tells me, that the plugin is not compatible with this version of SH3D. I went on, and downloaded the 32 bit version instead. But... Running the terminal script, in the SH3D folder does nothing. A terminal window flashes, and closes. No more. What can I do?
From the top menu choose Photo-video rendering -> Simple photo rendering (v1.6) and a pop-up window appears that's slightly different from the "normal" rendering window. Check your settings, and GO. (Normally that should work)
+45 Denmark
Oh yes, I understand. But when I click the "photo video rendering" menu-item, the window doesn't pop up. Nothing happens.
Run Sweet Home 3D from a Terminal window. If the plug-in is incompatible some way, an error should appear in the Terminal window when you select one of its menu items.
