when compiling from source SH3D and generating the docs, I get the following errors:
[javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:76: error: bad use of '>' [javadoc] * (pieceOfFurniture | doorOrWindow | furnitureGroup | light)*, wall*, room*, polyline*, dimensionLine*, label*)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:85: error: bad use of '>' [javadoc] * furnitureDescendingSorted (false | true) "false"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:87: error: bad use of '>' [javadoc] * <!ELEMENT property EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:90: error: bad use of '>' [javadoc] * value CDATA #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:92: error: bad use of '>' [javadoc] * <!ELEMENT furnitureVisibleProperty EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:93: error: bad use of '>' [javadoc] * <!ATTLIST furnitureVisibleProperty name CDATA #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:95: error: bad use of '>' [javadoc] * <!ELEMENT environment ((camera | observerCamera)*, texture?, texture?) > [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:115: error: bad use of '>' [javadoc] * videoFrameRate CDATA "25"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:117: error: bad use of '>' [javadoc] * <!ELEMENT backgroundImage EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:127: error: bad use of '>' [javadoc] * visible (false | true) "true"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:129: error: bad use of '>' [javadoc] * <!ELEMENT print EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:143: error: bad use of '>' [javadoc] * paperOrientation (PORTRAIT | LANDSCAPE | REVERSE_LANDSCAPE) #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:145: error: bad use of '>' [javadoc] * <!ELEMENT compass (property*)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:154: error: bad use of '>' [javadoc] * visible (false | true) "true"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:165: error: bad use of '>' [javadoc] * fieldOfView CDATA #REQUIRED'> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:167: error: bad use of '>' [javadoc] * <!ELEMENT camera (property*)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:170: error: bad use of '>' [javadoc] * attribute (topCamera | storedCamera | cameraPath) #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:172: error: bad use of '>' [javadoc] * <!ELEMENT observerCamera (property*)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:176: error: bad use of '>' [javadoc] * fixedSize (false | true) "false"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:178: error: bad use of '>' [javadoc] * <!ELEMENT level (property*, backgroundImage?)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:187: error: bad use of '>' [javadoc] * viewable (false | true) "true"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:200: error: bad use of '>' [javadoc] * price CDATA #IMPLIED'> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:202: error: bad use of '>' [javadoc] * <!ELEMENT furnitureGroup ((pieceOfFurniture | doorOrWindow | furnitureGroup | light)*, property*, textStyle?)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:212: error: bad use of '>' [javadoc] * dropOnTopElevation CDATA #IMPLIED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:241: error: bad use of '>' [javadoc] * currency CDATA #IMPLIED'> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:249: error: bad use of '>' [javadoc] * heightInPlan CDATA #IMPLIED'> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:251: error: bad use of '>' [javadoc] * <!ELEMENT pieceOfFurniture (property*, textStyle?, texture?, material*, transformation*)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:255: error: bad use of '>' [javadoc] * %pieceOfFurnitureHorizontalRotationAttributes;> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:257: error: bad use of '>' [javadoc] * <!ELEMENT doorOrWindow (sash*, property*, textStyle?, texture?, material*, transformation*)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:270: error: bad use of '>' [javadoc] * boundToWall (false | true) "true"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:272: error: bad use of '>' [javadoc] * <!ELEMENT sash EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:278: error: bad use of '>' [javadoc] * endAngle CDATA #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:280: error: bad use of '>' [javadoc] * <!ELEMENT light (lightSource*, property*, textStyle?, texture?, material*, transformation*)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:285: error: bad use of '>' [javadoc] * power CDATA "0.5"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:287: error: bad use of '>' [javadoc] * <!ELEMENT lightSource EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:293: error: bad use of '>' [javadoc] * diameter CDATA #IMPLIED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:295: error: bad use of '>' [javadoc] * <!ELEMENT textStyle EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:302: error: bad use of '>' [javadoc] * alignment (LEFT | CENTER | RIGHT) "CENTER"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:304: error: bad use of '>' [javadoc] * <!ELEMENT texture EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:317: error: bad use of '>' [javadoc] * image CDATA #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:319: error: bad use of '>' [javadoc] * <!ELEMENT material (texture?)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:324: error: bad use of '>' [javadoc] * shininess CDATA #IMPLIED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:326: error: bad use of '>' [javadoc] * <!ELEMENT transformation EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:329: error: bad use of '>' [javadoc] * matrix CDATA #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:331: error: bad use of '>' [javadoc] * <!ELEMENT wall (property*, texture?, texture?, baseboard?, baseboard?)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:350: error: bad use of '>' [javadoc] * rightSideShininess CDATA "0"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:352: error: bad use of '>' [javadoc] * <!ELEMENT baseboard (texture?)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:357: error: bad use of '>' [javadoc] * color CDATA #IMPLIED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:359: error: bad use of '>' [javadoc] * <!ELEMENT room (property*, textStyle?, textStyle?, texture?, texture?, point+)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:375: error: bad use of '>' [javadoc] * ceilingShininess CDATA "0"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:377: error: bad use of '>' [javadoc] * <!ELEMENT point EMPTY> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:380: error: bad use of '>' [javadoc] * y CDATA #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:382: error: bad use of '>' [javadoc] * <!ELEMENT polyline (property*, point+)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:395: error: bad use of '>' [javadoc] * closedPath (false | true) "false"> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:397: error: bad use of '>' [javadoc] * <!ELEMENT dimensionLine (property*, textStyle?)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:404: error: bad use of '>' [javadoc] * offset CDATA #REQUIRED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:406: error: bad use of '>' [javadoc] * <!ELEMENT label (property*, textStyle?, text)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:415: error: bad use of '>' [javadoc] * outlineColor CDATA #IMPLIED> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/io/HomeXMLHandler.java:417: error: bad use of '>' [javadoc] * <!ELEMENT text (#PCDATA)> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/DoorOrWindow.java:67: error: reference not found [javadoc] * {@link #isBoundToWall() bouldToWall} flag is <code>true</code>. [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/Home.java:1658: error: invalid use of @return [javadoc] * @return version the new version [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/HomePieceOfFurniture.java:1297: error: malformed HTML [javadoc] * of a rotated model created with version < 5.5. [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/HomePieceOfFurniture.java:1309: error: malformed HTML [javadoc] * @return <code>false</code> by default if version < 5.5 [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/Polyline.java:260: error: bad use of '>' [javadoc] * @throws IndexOutOfBoundsException if <code>index</code> is negative or > <code>getPointCount()</code> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/Polyline.java:281: error: bad use of '>' [javadoc] * @throws IndexOutOfBoundsException if <code>index</code> is negative or >= <code>getPointCount()</code> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/Polyline.java:301: error: bad use of '>' [javadoc] * @throws IndexOutOfBoundsException if <code>index</code> is negative or >= <code>getPointCount()</code> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/Room.java:272: error: bad use of '>' [javadoc] * @throws IndexOutOfBoundsException if <code>index</code> is negative or > <code>getPointCount()</code> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/Room.java:294: error: bad use of '>' [javadoc] * @throws IndexOutOfBoundsException if <code>index</code> is negative or >= <code>getPointCount()</code> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/model/Room.java:315: error: bad use of '>' [javadoc] * @throws IndexOutOfBoundsException if <code>index</code> is negative or >= <code>getPointCount()</code> [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:185: error: malformed HTML [javadoc] * "" < "1" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:186: error: malformed HTML [javadoc] * "0" < "1.0" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:187: error: malformed HTML [javadoc] * "1.2beta" < "1.2" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:188: error: malformed HTML [javadoc] * "1.2beta" < "1.2beta2" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:189: error: malformed HTML [javadoc] * "1.2beta" < "1.2.0" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:190: error: malformed HTML [javadoc] * "1.2beta4" < "1.2beta10" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:191: error: malformed HTML [javadoc] * "1.2beta4" < "1.2" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:192: error: malformed HTML [javadoc] * "1.2beta4" < "1.2rc" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:193: error: malformed HTML [javadoc] * "1.2alpha" < "1.2beta" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:194: error: malformed HTML [javadoc] * "1.2beta" < "1.2rc" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:195: error: malformed HTML [javadoc] * "1.2rc" < "1.2" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:196: error: malformed HTML [javadoc] * "1.2rc" < "1.2a" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:197: error: malformed HTML [javadoc] * "1.2" < "1.2a" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:198: error: malformed HTML [javadoc] * "1.2.0" < "1.2a" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:199: error: malformed HTML [javadoc] * "1.2a" < "1.2b" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:200: error: malformed HTML [javadoc] * "1.2a" < "1.2.1" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:201: error: malformed HTML [javadoc] * "1.7.0_11" < "1.7.0_12" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:202: error: malformed HTML [javadoc] * "1.7.0_11rc1" < "1.7.0_11rc2" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:203: error: malformed HTML [javadoc] * "1.7.0_11rc" < "1.7.0_11" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:204: error: malformed HTML [javadoc] * "1.7.0_9" < "1.7.0_11rc" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:205: error: malformed HTML [javadoc] * "1.2" < "1.2.1" [javadoc] ^ [javadoc] /var/tmp/portage/media-gfx/sweethome3d-6.1/work/SweetHome3D-6.1-src/src/com/eteks/sweethome3d/tools/OperatingSystem.java:206: error: malformed HTML [javadoc] * "1.2" < "1.2.0.1"
I am using JDK 1.8.0.202, looking at here a workaround is to disable doclint but probably it is better to fix the way the HTML code is inserted in the source code.
