Nederland
Re: Opening a door
perhaps this topic will help you in Features use and tips Door swing in plan
Nederland
Re: Opening a door
a simple solution is using a Door frame and set the door at a angle
Re: Opening a door
[Moderated] My Google search for "sweet home 3d open door" turns up this thread, which has over 5000 views, so I assume people want to know how to open a door in Sweet Home 3D, like I did. This is not explained anywhere for new users.
The answer, for anyone wondering, is to double-click on the door, or right-click and select "Modify furniture". In the pop-up, click the "Modify openings" button. From there you can see a 3D model of the door which you can click and drag to swing the door open or closed. Click OK to close the popups once you are done.
[Edit 1 times,
last edit by Puybaret at Apr 11, 2024, 2:27:06 PM]
Re: Opening a door
maladroit, the solution you propose will work only for the doors in the existing libraries. For door models designed by yourself, it's more complicate.
