Photo-rendering failed
This topic has been viewed 10963 times and has 15 replies
Thread status: Active
Still a problem with your graphic card? [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
decasicko
Country: Spain
Re: Photo-rendering failed
Post by decasicko »
After some PM with Hans, and checking Installing/Uninstalling some times Java and Sweethome3d, we determine, the problem is my computer.
I made a fresh install in a laptop and works fine. (Even modifying .ini file to adjust max memory), but my computer (I7 with W10 /16GB RAM/4GB graphic card) doesn't change, offering me maximum 0.4GB.
so maybe some software installed in my computer makes SH3H having incompatibility.
I will continue trying options in my computer, and until i find a solution, i will edit with my computer, and i will render with the laptop (Less powerful)
User avatar
UbuntuBirdy
Country: Switzerland
Contact:
Post by UbuntuBirdy »
You're sure you have installed 64bit JAVA?
Pascal
User avatar
Country: Netherlands
Post by hansmex »
The problem with decasicko is/was that he tried to render a 100MB file in 0.5 MB memory. He is now trying to increase memory allowance on his PC.
decasicko
Country: Spain
Post by decasicko »
Bu my computer doesn't let me more than 0.4Gb, although i have 16GB RAM.
I tested in other two computers and works fine, and memory allowance is good figures.
Something in my computer is not working well.
So, because is my problem, and not a program problem, i don't want to disturb.
If i reach a solution i will tell you in case somebody else share my problem.
User avatar
Country: Paris, France
Contact:
Post by Puybaret »
Does the About dialog box show 32bit or 64bit?
decasicko
Country: Spain
Post by decasicko »
Hello all. SOLVED.
Finally using this video (https://www.youtube.com/watch?v=R3Hj83J0ekk), and Changing the value in the first step (I modify it with -XMX8g not delete) and now i start SH3D and i see:
Java version 1.8.0_202 - 64 bit - 0.1 / 7.1 GB
So finally it's working.
thanks a lot to all of us hwo helped me here or with Private Message.
so the problem was, my system was blocking any change of memory in JAVA restricting to 512MB.
Post Reply New Topic
Who is online
Users browsing this forum: Amazon [Bot], Bing [Bot]
