Re: KItchen cabinets without the latest wizardry.
@ veroniQ there is room for stools just not included any. @ Adele i drew walls around the cabinets, created a room in them, deleted the walls, exported the room, after unchecking ceiling and display area, then copied it, added 20 mm to the width and length, 4 times, then stacked them up then used the alignment tool on 2 edges to position them. Could have just used walls, adjusting the wall thickness for each layer, but that would mean 4 exports.
Having realised that the handle i used on these cabinets should not have been shared i have cancelled all the links for downloading the files, images containing the cabinets are ok. My apologies for any inconveniences. Mike
Bdfd, the Terms of use of Trimble 3D Warehouse don’t let people redistribute their models, or distribute a design derived from them. So, you can include Trimble Warehouse 3D models in a SH3D file but not distribute that file (or a part of that file). Showing an image of such a SH3D file shouldn’t be an issue because the 3D information is lost in that case.
Yes, I forgot to add 'FREE' in 'We can find all kinds of free handles on 3dwarehouse..." .
only 6.2 and nothing else - W10 64b Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To, MSI GeForce RTX 2080 8Go
As far as I know, all models available on Trimble 3D Warehouse are distributed under the same license.
By the way, in case some of you wonder how some Reallusion models found on Trimble 3D Warehouse could end up in Sweet Home 3D free models library, it’s because Reallusion granted me the right to distribute these models under CC-BY license too.
