Total posts in this thread: 2
Previous Thread This topic has been viewed 1736 times and has 1 reply Next Thread
Havouza
Cypern
How place windows on correct height
Hi!
Newbi question
How do I place a window on the correct height on a wall. They seems to be places with same distance from floor and celing and that is not correct
Regards
[Mar 10, 2019, 11:33:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How place windows on correct height
If you know the height you want them, then you can change the windows elevation 1 at a time or as a collection, if they are all the same. To change its elevation right click on the object and select "modify" from the drop down menu. The ones in the library will not be exact for each project as each room height can be different.
[Mar 10, 2019, 6:38:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
