Re: scale up 3D view? // 2 homes .. to bring together?
Could you copy/paste from 1 to the other. Not sure about the size of the view, check the viewer position for each and that both are on either arial or virtual. Mike
All at once , left click and drag the mouse over, or right click >select all, or you could hold the ctrl key and select as many as you wish. i would suggest you copy 1 item across first, compare its location when sited in the other room and use the "move" tool to position, remember the x and y values you move it, these can then be used to move all the other items.
