Re: Installation of the last upgraded version in Ubuntu
Your SH3D installation should not be in the /home/.eteks folder, this folder is for your personal additional files like furniture you are adding or plugins. My SH3D installation e.g. is in the usr/share folder and there in a separate folder for each version of SH3D. In this way, I can test the latest version first before I delete the old one.
Pascal
New Zealand
I also like to keep several versions around. I use a symbolic link such as Live or Latest to point to the one that desktop users should be using.
I also like keep the install in a filesystem that is separate from the OS (to avoid OS upgrades clobbering anything). Either under /home/local or /usr/local depending on the organisation of the available drives.
Coming soon, Ubuntu 18.04, also known as Bionic Beaver, and the upcoming long-term version of Canonical's famous Linux distribution will be available. This means that it is time to consider how to update to the latest and greatest versions of Ubuntu Linux.
First, keep in mind that this Ubuntu will not look like the latest versions. In fact, Ubuntu returns to GNOME for its default Unity desktop. The difference is not that great, but if you are already comfortable with what you are running, you may want to wait a moment before moving on to the next one.
