Downloaded latest version SH3D 6.1.2 from this website and expanded archive in /etc/sh3d on my ubuntu 18.1.2 LTS laptop
Couldn't start the application nor could the java version.
Then moved the directory to /usr/share/sh3d
apllication doesn't start
a) what did I do wrong /omit to do during install
b) is there a verbose/debug mode form terminal such that i can see error messages?
New SH3D install doesn't work
This topic has been viewed 7068 times and has 3 replies
Re: New SH3D install doesn't work
starting the application from the command line in terminal results in Command not found
d---@---Ubuntu:/usr/share/SweetHome3D-6.1.2$ dir
COPYING.TXT THIRDPARTY-LICENSE-ITEXT.TXT
jre8 THIRDPARTY-LICENSE-JAVA3D.TXT
lib THIRDPARTY-LICENSE-JAVA.TXT
LICENSE.TXT THIRDPARTY-LICENSE-JEKSPARSER.TXT
SweetHome3D THIRDPARTY-LICENSE-JMF.HTML
SweetHome3DIcon.png THIRDPARTY-LICENSE-SUNFLOW.TXT
SweetHome3D-Java3D-1_5_2 THIRDPARTY-LICENSE-TANGO.TXT
THIRDPARTY-LICENSE-BATIK.TXT THIRDPARTY-LICENSE-VECTORGRAPHICS.TXT
d---@---Ubuntu:/usr/share/SweetHome3D-6.1.2$ SweetHome3D
SweetHome3D: command not found
Wrong is the place where You expand the archive.
You don't need to be root to run this program.
Expand it as user in Your home folder (autodetect folder option);
In the newly created folder double click on SweetHome3D file and chose Execute.
From the command line, you should add [font=courier new]./[/font] in front of [font=courier new]SweetHome3D[/font] :
Code: Select all
./SweetHome3DEmmanuel Puybaret, Sweet Home 3D creator
Who is online
