Re: Missing surfaces on imported models.
Hi, The model imports into ArtOfIllusion OK. Applying a texture or uniform colour doesn't make the missing surfaces re-appear
On closer examination it doesn't appear to matter what angle I look at the handrail from I can always see the inside of the surfaces, never the outside. So they are there, but the outside surface is not being rendered.
Polen
Hi Baldy,
There are two basic questions on Your Model: 1. What render engine do You use in Blender (mght be also fine to know what Blender Version) 2. You used the extrude for the rail, as a modifier?
Both things will make it uneasy to get the right OBJ (MTLs) out of Blender.
So first rule of thumb: Do not use cycles and here do not use procedural textures, they will not come into OBJ and MTL Seccond, apply all modifiers, prior to export. third: Blender has some issues with the MTL creation on Texture pictures. The propriate lines are not included into the mtl.
OK, so, if I carve out the handrail using boolean subtraction it comes out right. If I extrude it from a flat shape it comes out back to front.
In blender they look similar but SH3D interprets them differently.
I tried to diff the OBJ files but there were too many differences. I can export just the handrails in each case and compare them. Don't know if the devs would find this useful for future reference?
