Total posts in this thread: 6
Previous Thread This topic has been viewed 2375 times and has 5 replies Next Thread
Luzi3D
"schräge" Box zeichnen?
Hallo,
gibt es die Möglichkeit, eine Kist so zu editieren, dass sie nicht rechtwinklig ist, sondern in der Draufsicht schräge Kanten hat? Ich hoffe, man versteht, was ich meine ;)
Danke und LG
Luzi
[Apr 27, 2019, 10:24:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: "schräge" Box zeichnen?
I am not sure if you can edit a box, but you can certainly make the shape you describe with the shape generator tool, you will find it tools>generate 3d shape
[Apr 27, 2019, 11:38:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Luzi3D
where do I find "tools"?
Thanks!!
[Apr 28, 2019, 11:16:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
drop down box top left of main screen file...edit...Furniture...etc
[Apr 28, 2019, 11:19:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Luzi3D
Ahh found it, it's a plug in :)Thank you!!
[Apr 28, 2019, 11:28:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If the shape you require has more points than the generator allows then an option would be to draw the profile of your shape with the "create room tool, this will need to be done on an elevated level, not 0 elevation, then export it, 3D view>export to obj format, then import it, furniture> import furniture, during the import process you can re-orientate the object.
[Apr 28, 2019, 11:46:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
