"schräge" Box zeichnen?
Hallo, gibt es die Möglichkeit, eine Kist so zu editieren, dass sie nicht rechtwinklig ist, sondern in der Draufsicht schräge Kanten hat? Ich hoffe, man versteht, was ich meine ;) Danke und LG Luzi
Re: "schräge" Box zeichnen?
I am not sure if you can edit a box, but you can certainly make the shape you describe with the shape generator tool, you will find it tools>generate 3d shape Mike
If the shape you require has more points than the generator allows then an option would be to draw the profile of your shape with the "create room tool, this will need to be done on an elevated level, not 0 elevation, then export it, 3D view>export to obj format, then import it, furniture> import furniture, during the import process you can re-orientate the object.
