Total posts in this thread: 6
Previous Thread This topic has been viewed 3512 times and has 5 replies Next Thread
MichaelN
Rendering Issue if open more than one flat
Is there a known issue when opening a second file / flat?
3D view works, but the 2D screen shows red squares instead of the common furnitures view.
see https://we.tl/t-grkGO5Ssaz
[May 21, 2019, 6:05:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
confused Re: Rendering Issue if open more than one flat
And ??? biggrin
What is the configuration of your PC ?
[May 21, 2019, 7:39:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
This sounds like a memory problem. What memory use is indicated in the About dialog? Did you try to increase the max memory if possible?
[May 22, 2019, 9:48:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MichaelN
OK, I created such a ini file with 1000M (tried 1200M, but SH3D doesn't start anymore) and SH3D uses 0,5-0,6 GB of 0,9 GB - red squares :-( Is 900 MB the maximum?
My PC is a HP spectre with 16 GB RAM and two 4k Monitors (1 generic, 1 via DisplayLink) @Win10 64bit
[May 22, 2019, 7:05:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Run the installer again and select the 64 bit architecture in the screen that lets you choose the installation folder.
[May 23, 2019, 12:55:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MichaelN
THX, that helps. Now I have V6.1.2 and this installer has an option to choose between 32 and 64 bit. With 64bit the rendering works fine.
[May 28, 2019, 5:46:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
