Re: Rendering Issue if open more than one flat
And ???
What is the configuration of your PC ? .
SH3D 6.4.2 and nothing else - W10 64b Asus TUF Z390 , Intel Core i9-9900KF (4.0 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3 Ghz, SSD M.2 512 Go + HDD 3 To, MSI GeForce RTX 2080 8Go
This sounds like a memory problem. What memory use is indicated in the About dialog? Did you try to increase the max memory if possible?
OK, I created such a ini file with 1000M (tried 1200M, but SH3D doesn't start anymore) and SH3D uses 0,5-0,6 GB of 0,9 GB - red squares :-( Is 900 MB the maximum?
My PC is a HP spectre with 16 GB RAM and two 4k Monitors (1 generic, 1 via DisplayLink) @Win10 64bit
Run the installer again and select the 64 bit architecture in the screen that lets you choose the installation folder.
