New home with, hopefully curb appeal.
This topic has been viewed 15179 times and has 10 replies
Thread status: Active
Share your snapshots made with Sweet Home 3D here [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Country: UK
Post by Mike53 »
I wanted to do a building, which, as the topic says, has curb appeal, something you might just pause to look as as you passed. not sure i have managed to achieve that, it has ended up looking more like a town hall, but maybe as it develops. Anyway here are a few images.
Inside all that has been done is the floors and a staircase, i say all, but it took a while.
The handrail i made separately everything else is components straight from the library
Country: UK
Re: New home with, hopefully curb appeal.
Post by Mike53 »
And a Link to view it.
Country: France
Post by VeroniQ »
Interesting, fun and well done, Mike! I only don't understand why did you need to design so many levels (according to your link)...
User avatar
Country: LILLE, Les Hauts de France, Western Europa
Post by bdfd »
Perhaps :
for a big familly,
for a little Community,
for the challenge…
Country: UK
Post by Mike53 »
Hi VeroniQ
Glad you liked it
The levels between the main floors have on them various walls, for instance, level 7 has walls which form the risers for the middle section of stairs, they are roughly triangular, but to avoid using 2 boxes and a triangle, which would not texture evenly, i prefer to use a wall, also these levels have the floor depth set to 1 mm so the minimum wall height does not include a floor depth. [:)]
User avatar
UbuntuBirdy
Country: Switzerland
Contact:
Post by UbuntuBirdy »
I often use supporting levels like Mike does. For example my Luxemotor projects has 8 of them. I try to use the next deeper level as often as possible, but sometimes it's more comfortable to insert a supporting level, even on the same height if needed. This solution is easier to handle than grouping furniture, because for example hideing a whole level includes also the walls and floors on it and you can't do this with groups.
Pascal
User avatar
UbuntuBirdy
Contact:
...oh, and Mike, nice project and well done!
Pascal
Country: UK
Post by Mike53 »
Hi Pascal, thank you.
As far as using groups or levels, it just shows the versatility of this software, so thank you to Emmanuel as well.
User avatar
Country: Copenhagen, Denmark
Contact:
Post by Ceciliabr »
Nice work, again!
As for using levels, I absolutely agree. I use levels in SH3D the same way I use layers in Photoshop.
It would be nice though, if we could group or link levels, and make snapshots of different level-configurations.
User avatar
Contact:
Post by Ceciliabr »
Just watched your 3D model, and I must say that your roof construction is very nice.
Solid work!
Cecilia
Post Reply New Topic
Who is online
Users browsing this forum: Google [Bot]
