Features
Posts: 26   Pages: 3   [ 1 2 3 | Next Page ]
Previous Thread This topic has been viewed 95662 times and has 25 replies Next Thread
ichklaus
Roadmap
Is there a roadmap?
When approximately will version 1.3 be launched?
In January?
I´m looking forward to it...
Good job puybaret!
Keep it up!
Best wishes!
Klaus
[Nov 15, 2007 4:10:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Roadmap
Thank you for launching this discussion about Sweet Home 3D roadmap.
I wanted to create a web page for it, but finally this forum is the easiest way.
Here's the features roadmap I've got in mind at this time:
- v 1.3 : creation and modification of home rooms, with textures applicable to room's floor and cellar
- v 1.4 : ergonomic stuff : automatic depth of windows and doors placed on walls, stick and orientate objects to the approach of a wall, better management of magnetism
- v 1.5 : management of lights
- v 2.+ : management of multiple floors, roofs, export to other formats...
v 1.3 shouldn't be available before February or March 2008 (I have to earn some money first ;-).
[Nov 15, 2007 6:22:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
Re: Roadmap
Just this message to announce that probably, Sweet Home 3D v 1.3 won't be available before this summer, because I don't have enough free time right now to program more things that maintenance releases.
[Feb 10, 2008 8:43:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
jeroen_roeterd
Re: Roadmap
Hello,
Just letting you know that I discovered your application just hours ago and like it very much. The features you name in later releases would make it much better (spec. floor and cellar textures). Keep up the good work (after earning a living of course ;-))
Greetings form the Netherlands,
Jeroen
[Mar 4, 2008 7:36:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Wolf_Skafte_Zauss
Re: Roadmap
Hi there
I love your project and was wondering if there is any way of of making it
a web based application.
My idea is to offer our customers the facility to create their own floor
plans on-line.
Any information on this would be appreciated and if we could make this
happen then I would be happy to become a sponsor for your project.
Have a great day
Wolf Skafte-Zauss
Contemporary Door & Cabinet Hardware specialists.
http://www.bluewolf.net.au
1300 738 936 Fax: 02 9012 0193
[May 30, 2008 2:08:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Roadmap
From the description of versions 1.3 and 1.4 at http://sweethome3d.sourceforge.net/history.html , you may guess that the roadmap proposed one year ago changed a little. ;-)
So, here's the new roadmap I've got in mind at this time:
- v 1.5 : creation and modification of home rooms (with textures applicable to room's floor and cellar), and creation of free text labels in the plan
- v 1.6 : ergonomic stuff : automatic depth of windows and doors placed on walls, stick and orientate objects to the approach of a wall
- v 1.7 : management of lights
- v 2.+ : management of multiple floors, roofs...
Meanwhile, I might also test an on-line applet version of Sweet Home 3D.
I prefer to promise no delivery date, but be reassured, I'm still spending a lot of time on Sweet Home 3D development.
[Oct 8, 2008 12:08:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
vincecat
Re: Roadmap
Bonjour monsieur Puybaret.
Un grand merci pour votre travail.
J'utilise Sweet Home 3D depuis la v1.3 et je suis toujours autant impressionné par la simplicité de SH3D au regard de sa puissance.
La dernière petite merveille, l'online applet, est sur mon site (ecolonomiqhome.free.fr). Elle fonctionne aussi bien que le reste.
J'ai un peu honte, surtout que je ne vous ai pas encore fait de don, de vous demander un ajout à votre roadmap:
- pourriez-vous ajouter l'export DXF ou DWG en plus du SVG.
Les raisons de cette demande sont l'échec de conversion du SVG, créé par SH3D, en DXF via Inkscape (je peux vous faire parvenir les fichiers ainsi que les messages d'erreur d'Inkscape si vous le souhaitez).
Le format DXF est le plus commun pour l'import de plan dans les logiciels du bâtiment comme Alcyone+Comfie+Pleiade (simulation thermodynamique) et Dialux (simulation d'éclairage).
En tout cas, que vous le fassiez ou pas, un grand merci d'avoir créé SH3D.
Cordialement.
[May 7, 2009 12:42:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Roadmap
Pour ne pas alourdir le logiciel, je ne pense pas ajouter d'autre format d'export dans un avenir immédiat (à part peut-être pour les images de la vue 3D), mais ce genre d'exportation pourrait être réalisé à l'aide d'un plug-in (y'a-t-il un volontaire dans la salle ? ;-).
Il existe peut-être aussi un convertisseur autre que Inkscape qui fonctionne...
Vous pouvez aussi signaler le bug à l'équipe d'Inkscape pour qu'ils essaient de le corriger.
[May 7, 2009 2:43:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
vincecat
Re: Roadmap
Je comprend.
Pour le convertisseur qui fonctionne, oui il y en a un: ivcon (un executable en ligne de commande trouvé ici).
Mais la visu sous Comfie, confirmée avec Cadviewer, du DXF obtenu m'a vraiment surpris. Inexploitable dans mon cas.
Merci et bonne continuation pour la v2.
Cordialement
[May 7, 2009 11:19:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Roadmap
Now that version 2.0 is out, here's a list of the main features that will probably appear in the 2.+ releases:
- Grouping/ungrouping furniture
- Better furniture catalog pane for catalog containing many pieces
- New Display menu to let user choose which pane to display
- New wizard to create 3D models from pictures applied on the faces of a cube, sphere or cylinder
- Creation of videos from a virtual visit
- Improvement of lights management
- Management of levels
- Management of roofs
- Manage portability to simplify the moving of Sweet Home 3D
[Aug 7, 2009 11:55:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
