Additional Sunflow options (tests)
Sunflow has command line options to control the rendering result without the GUI. The goal here is to test their actions in Sweet Home 3D.
* Option: -threads X Allows you to force the number of threads used for rendering (BucketRenderer, MultipassRenderer). Default value: number of available processors.
SH3D implementation: int threads = X; this.sunflow.parameter("threads", threads); this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS);
No major differences in rendering time if the number of virtual threads is greater than the number of actual threads available.
* Options: -lopri -hipri Allows you to set the priority of the threads. Default value: lowPriority = true.
Re: Additional Sunflow options (tests)
* Options: -quick_uvs : Renders the UVs of objects. -quick_normals : Renders the normals of objects. -quick_id : Renders using a unique color for each instance. -quick_prims : Renders using a unique color for each primitive. -quick_gray : Renders all the objects in the scene gray diffuse, overriding all shaders. -quick_wire : Renders objects as wireframe. -quick_ambocc X : Renders a scene in ambient occlusion mode with a certain distance (X). Only one override shader at a time can be used.
Nice renderings!
Thank you VeroniQ! I take the opportunity to propose a small survey.
Among the new rendering options, which ones do you find most interesting?
A: show_uvs
B: show_normals
C: show_instance_id
D: show_primitive_id
E: quick_gray
F: wireframe
G: ambient_occlusion (X)
EnkoNyito
[Edit 1 times,
last edit by enkonyito at Jun 5, 2019, 5:22:48 PM]
Cameroun
Hello hello community how to install SunFlow I would like to improve my rendering and how to use it? i have already downloaded but there is no executable file
Thank you william from Cameroon
--------------------------------------------------------------- Hello bonjour la communaute comment installer SunFlow je voudrais ameliore mes rendue et comment l utiliser? j ai telecharger deja mais il ya pas de fichier executable
