Previous Thread This topic has been viewed 14095 times and has 13 replies Next Thread
enkonyito
Additional Sunflow options (tests)
Sunflow has command line options to control the rendering result without the GUI.
The goal here is to test their actions in Sweet Home 3D.
* Option:
-threads X
Allows you to force the number of threads used for rendering (BucketRenderer, MultipassRenderer).
Default value: number of available processors.
SH3D implementation:
int threads = X;
this.sunflow.parameter("threads", threads);
this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS);
No major differences in rendering time if the number of virtual threads is greater than the number of actual threads available.
* Options:
-lopri
-hipri
Allows you to set the priority of the threads.
Default value: lowPriority = true.
boolean lowPriority = true;
this.sunflow.parameter("threads.lowPriority", !lowPriority);
No major differences in rendering time.
EnkoNyito
[Jun 3, 2019, 12:18:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Re: Additional Sunflow options (tests)
* Option:
-showaa
Display sampling levels per pixel for bucket renderer.
Default value: showAA = false.
boolean showAA = false;
this.sunflow.parameter("aa.display", !showAA);
showAA = true
showAA = false
EnkoNyito
[Jun 4, 2019, 4:32:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
* Options:
-quick_uvs : Renders the UVs of objects.
-quick_normals : Renders the normals of objects.
-quick_id : Renders using a unique color for each instance.
-quick_prims : Renders using a unique color for each primitive.
-quick_gray : Renders all the objects in the scene gray diffuse, overriding all shaders.
-quick_wire : Renders objects as wireframe.
-quick_ambocc X : Renders a scene in ambient occlusion mode with a certain distance (X).
Only one override shader at a time can be used.
String shaderOverride = null; // "show_uvs","show_normals","show_instance_id","show_primitive_id","quick_gray","wireframe","ambient_occlusion"
if (shaderOverride.equals("ambient_occlusion")) {
float maxDist = 200f;
this.sunflow.parameter("maxdist", maxDist);
this.sunflow.shader("cmdline_override", shaderOverride);
this.sunflow.parameter("override.shader", "cmdline_override");
shaderOverride != null
EnkoNyito
[Jun 5, 2019, 12:01:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Nice renderings!
[Jun 5, 2019, 12:38:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Nice renderings!
Thank you VeroniQ!
I take the opportunity to propose a small survey.
Among the new rendering options, which ones do you find most interesting?
A: show_uvs
B: show_normals
C: show_instance_id
D: show_primitive_id
E: quick_gray
F: wireframe
G: ambient_occlusion (X)
EnkoNyito
[Edit 1 times, last edit by enkonyito at Jun 5, 2019, 5:22:48 PM]
[Jun 5, 2019, 4:36:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
I like E: Quick Grey but the colored ones (especially C and D) are fun!
[Jun 5, 2019, 5:42:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ndorigatti
Italia
quick gray, wireframe and ambient occlusion (E F G)
[Jun 5, 2019, 7:42:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
The additional Sunflow options plug-in will be available with the new version of the photo-video plug-in.
Enko
EnkoNyito
[Jul 1, 2019, 3:45:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
williamcm
Cameroun
Hello hello community
how to install SunFlow
I would like to improve my rendering and how to use it? i have already downloaded but there is no executable file
Thank you william from Cameroon
Hello bonjour la communaute
comment installer SunFlow
je voudrais ameliore mes rendue et comment l utiliser? j ai telecharger deja mais il ya pas de fichier executable
Merci william depuis le cameroun
[Aug 5, 2019, 1:33:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Hi William!
You can download the precompiled version Sunflow-v0.07.2 and run the sunflow.jar file directly or sunflow.bat after editing.
You can also download the latest version Sunflow-v0.07.3 and follow the build instructions of the README file.
Enko Nyito
EnkoNyito
[Aug 5, 2019, 5:20:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
