Total posts in this thread: 9
Previous Thread This topic has been viewed 4490 times and has 8 replies Next Thread
vincemay
Italia
Rendering: Java Error
Dear Friends
I have a big problem ! Please Help me.
Using Sweethome3d, upon rendering of a very large file (400 MB) returns a JAVA error that I transcribe:
"Java. Lang. OutOfMemoryError: GC OVERHEAD LIMIT EXCEEDED"
And sometimes even a Heap Space exception
At render time, if active artificial lighting, it produces the following error first. I don't think DAE models could cause the inconvenience because, do I render with daylighting without artificial lights or with those used for the Interior, the problem does not occur.
I don't know how to fix it. Mainly use a mobile PC with an INTEL i5 processor and 8 GB of ram now a little dated. But even on an ASUS laptop Intel i7 8 Gb ram 8000 series and the problem returns.
How do I fix. How to assign more memory to Java.
Thank you in advance and I look forward.
Kind regards.
Vincenzo
[Jul 8, 2019, 8:14:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Rendering: Java Error
Please read the FAQ How can I adjust the memory used by Sweet Home 3D?
[Jul 8, 2019, 10:18:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
vincemay
Italia
Thanks Emmanuel,
Now everything is ok. I assigned -Xmx 4096m and seems to fly.
[Jul 9, 2019, 1:11:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hi Emmanuel
I tried the numbers vincemay used but but sweethome would not start, halved the value, then halved it again, neither allowed sweethome to start
this is my pc
this is my sweethome version
Could you tell me what to add in the ini please.
As my pc is set i cannot work with any sh3d file over approx 60'000 kb, pc lags way to much in the 3d view, it can take 2 or 3 mins for the view to change just moving to a different level.
Thx
[Jul 9, 2019, 3:25:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
this is the error i am getting
[Jul 9, 2019, 3:44:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Mike, remove the space after -Xmx
The memory size should come just after, like in -Xmx2048m
[Jul 10, 2019, 12:58:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
thank you
With my set up what is the highest value am i able to use
[Jul 10, 2019, 11:32:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The usable maximum depends on how much RAM is available in your computer and how much memory is used by the system and other programs. Beyond that limit, there are chances that the computer will have to swap more often, slowing down everything.
If your computer has 16 GB RAM, I think -Xmx8g (8 GB) will let plenty of RAM for Sweet Home 3D.
[Jul 12, 2019, 2:11:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
thk you i will try it shortly smile
[Jul 12, 2019, 2:57:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
