Total posts in this thread: 2
Previous Thread This topic has been viewed 1098 times and has 1 reply Next Thread
maty87
uk
2D & 3D issues
hi im after some help when drawing walls on a level with a pattern down the walls drawn in 2D dosnt show on the plan but shows in the 3D view or how do I view anything on other levels through the plan view
[Jul 10, 2019, 9:35:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2D & 3D issues
You can change the pattern used to fill a wall thickness in the plan with the drop down list Pattern in plan available in the wall modification dialog box. You can change the pattern of multiple walls at the same time, by selecting them and choose Plan > Modify walls menu item.
[Jul 12, 2019, 1:40:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
