How to solve this roof issue?
This topic has been viewed 2553 times and has 7 replies
Thread status: Active
Post Reply New Topic
MichaelN
Post by MichaelN »
When I activate the roof in the room options then I see a grafic issue. See pictures. How could I solve it without creating my own roof out of boxes?
User avatar
Country: Netherlands
Re: How to solve this roof issue?
Post by hansmex »
Same old story... the walls surrounding the room are not of equal height.
MichaelN
Post by MichaelN »
I just checked it. The surrounding walls are all at the same height. Behind the door starts a wall with different level, but this shouldn't be influence this room?!
User avatar
Post by hansmex »
Simple test: make your ceilings invisible. If the anomaly disappears, you know where to look to solve the problem.
If you need help, send me your file.
MichaelN
Post by MichaelN »
Sure is the issue gone, if I deactivate the ceiling. See also picture #3. Can't find the issue. I edited the walls several times. Could it help to delete the room and create him again?
Country: UK
Post by Mike53 »
Cannot tell much from your images, something you could try is to extend the room slightly beyond the walls, to mid wall, in the area giving an issue.
I did notice, in the 2d image, 3 points in the room set up that are not needed, delete them too, 1 on the corners each side of the viewer.
Try to keep images a little smaller, give a better overall picture.
Country: UK
Post by Mike53 »
If that does not help then i would suggest you make all objects except doors hidden, save the file to share here, perhaps Hans or myself could spot something that would help
Country: UK
Post by Mike53 »
or... change the room settings so it shows no ceiling... make a copy... modify the copy to show only the ceiling, no walls or floor.....export it...import and position, one drawback is you will probably have to hide it when moving other objects in the hallway
Who is online
Users browsing this forum: Bing [Bot]
