Total posts in this thread: 8
Previous Thread This topic has been viewed 1407 times and has 7 replies Next Thread
MichaelN
How to solve this roof issue?
When I activate the roof in the room options then I see a grafic issue. See pictures. How could I solve it without creating my own roof out of boxes?
[Jul 13, 2019, 11:14:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: How to solve this roof issue?
Same old story... the walls surrounding the room are not of equal height.
[Jul 13, 2019, 11:47:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MichaelN
I just checked it. The surrounding walls are all at the same height. Behind the door starts a wall with different level, but this shouldn't be influence this room?!
[Jul 13, 2019, 2:39:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Simple test: make your ceilings invisible. If the anomaly disappears, you know where to look to solve the problem.
If you need help, send me your file.
[Jul 13, 2019, 2:48:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MichaelN
Sure is the issue gone, if I deactivate the ceiling. See also picture #3. Can't find the issue. I edited the walls several times. Could it help to delete the room and create him again?
[Jul 14, 2019, 3:47:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cannot tell much from your images, something you could try is to extend the room slightly beyond the walls, to mid wall, in the area giving an issue.
I did notice, in the 2d image, 3 points in the room set up that are not needed, delete them too, 1 on the corners each side of the viewer.
Try to keep images a little smaller, give a better overall picture.
[Jul 14, 2019, 3:59:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If that does not help then i would suggest you make all objects except doors hidden, save the file to share here, perhaps Hans or myself could spot something that would help
[Jul 14, 2019, 4:05:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
or... change the room settings so it shows no ceiling... make a copy... modify the copy to show only the ceiling, no walls or floor.....export it...import and position, one drawback is you will probably have to hide it when moving other objects in the hallway
[Jul 14, 2019, 11:19:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
