Total posts in this thread: 19
Posts: 19   Pages: 2   [ Previous Page | 1 2 | Next Page ]
Previous Thread This topic has been viewed 392014 times and has 18 replies Next Thread
Re: Bibliothèque pour multipostes
I created a new plug-in that allows users to export all the furniture imported in Sweet Home 3D catalog to a SH3F file, that you can import on an other computer with a double-click or with the menu item "Furniture > Import furniture library..." (the SH3F file is portable so you can import it even if the Operating System of the second computer is different from the one where you created the SH3F file).
Download this plug-in at http://sweethome3d.eu/plugins/ExportToSH3F-1.1.sh3p
Then copy it copy the ExportToSH3F-1.0.sh3p file in the plug-ins folder of Sweet Home 3D, which depends on your system as follows:
- under Windows, this folder is C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D\plugins,
- under Mac OS X, it's the subfolder Library/Application Support/eTeks/Sweet Home 3D/plugins of your user folder,
- under Linux and other Unix, it's the subfolder .eteks/sweethome3d/plugins of your user folder.
Relaunch Sweet Home 3D, and you'll see the new menu item "Export imported furniture to SH3F..." in Furniture menu. At this time this will work, only if you installed Sweet Home 3D 1.5 with its installers. If you installed it with Java Web Start, it may not work for security reasons and you'll have to download the installer.
!!!Caution!!!
Take care of the license of the models you export to a SH3F file. Almost all free models can't be redistributed, and the fact that Sweet Home 3D is free doesn't change anything to that. That's the reason why I had to create some models for the first versions of Sweet Home 3D!
[Note: plug-in was updated on 03/04/2024 to export some missing model flags]
[Edit 1 times, last edit by Puybaret at Mar 4, 2024, 2:19:38 PM]
[Dec 18, 2008, 1:24:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ioanmely
up !
alors des nouvelles de cette requette ?
[Sep 24, 2009, 7:38:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Avez-vous essayé le plug-in d'exportation cité dans le message précédent ?
Une fois installé, ce plug-in ajoute le menu Meubles > Exporter les meubles importés au format SH3F... dans Sweet Home 3D pour vous permettre de créer un fichier SH3F que vous pourrez copier sur un autre poste.
[Sep 27, 2009, 9:29:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maazito
Puybaret says:
"I created a new plug-in that allows users to export all the furniture imported in Sweet Home 3D catalog to a SH3F file, that you can import on an other computer with a double-click or with the menu item "Furniture > Import furniture library..." (the SH3F file is portable so you can import it even if the Operating System of the second computer is different from the one where you created the SH3F file).
Download this plug-in at http://sweethome3d.eu/plugins/ExportToSH3F-1.0.sh3p
Your plugin looks quite interesting, but (I am using a Mac OS X 10.5) there's no "eTeks" directory within "Library/Application Support/". Could you clarify? Where are the SH3D plugin stored on a Mac?
[Mar 18, 2010, 11:42:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sous Windows et Mac OS X, double-cliquez simplement sur un fichier SH3P pour l'installer.
Under Windows and Mac OS X, simply double-click on a SH3P file to install it.
[Mar 18, 2010, 6:09:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LANFEUST78
Bonjour et merci pour votre logiciel.
Question légèrement semblable. j ai récupérer sur google plusieurs objets au format OBJ et SKP après lecture de la notice seul le format OBJ me sera utile dans un premier temps.
J’ai vu que l’on pouvait importer en masse des objets, pour cela il faut créer un fichier au format SH3F.
Comment peut on créer se fichier ? ou puis je trouver la procédure ?
Je ne souhaite pas intégrer mes objets un par un. Merci a vous
La réponse est peut être dans un des messages sur le forum mais je ne l est pas trouvé. Ou bien je suis passé dessus sans le voir oups désolé ………
[Oct 1, 2010, 9:16:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Il faut télécharger l'Editeur de Bibliothèque de Meubles / Furniture Library Editor.
L'application est francisée mais je n'ai pas rédigé de doc en français encore.
Donc rendez-vous ici et utilisez Google translate si nécessaire.
[Oct 1, 2010, 10:08:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LANFEUST78
Ok super merci pour votre réponse hyper rapide .je regarde cela des ce soir . je vais donc pouvoir importer en masse mes objets cool . encore merci
[Oct 1, 2010, 12:05:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JayOH
Hello, I have just installed "Export imported furniture to SH3F", exported the furniture library and loaded it into "Furniture Library Editor".
I wasn't quite sure what to expect but the result seemed to be somewhat random. Only some of the library was displayed and not all of the items were from the house I am working on. For example only one item from "Bedroom was exported and that was a roof section that which I wrongly categorised.
I have not returned the results to SweetHome in case it corrupts what the Library.
Could you explain what I should expect from "Export imported furniture to SH3F". Is it supposed to export furniture that I have used in my project? or Is it supposed the whole Library Catalogue from SweetHome?
By the way, I am now getting the hang of using SweetHome3d and I absolutely love it.
[Jul 12, 2019, 11:10:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The ExportToSH3F plug-in exports only the pieces of furniture individually imported in Sweet Home 3D furniture catalog (i.e. with Furniture > Import Furniture menu item or a drag and drop of 3D model file in the catalog), not the furniture used in the opened SH3D document.
[Jul 12, 2019, 1:32:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
