Australia
Mirroring walls
Hi, I have a large amount of walls which are joined at unusual angles, and I would like to copy and paste them, but in mirrored orientation (for the other side of a building) but there is no <- to grab to turn them around. Is there an easy way to do this, or do I just have to reproduce each one manually?
Egypt
Re: Mirroring walls
hello , I am not sure if I understand your question , better if you post a screenshot illustration , but if you want to mirror a group of walls you can select them then copy and paste the new pasted walls will be now marked as selected , just right click and flip them horizontally or vertically but be careful not to lose selection by clicking away . another way by using "copy as new furniture " plugin http://www.sweethome3d.com/plugins/CopyAsNewFurniturePlugin-1.2.sh3p select walls you want and copy as new furniture then paste and flip in the direction you want . I hope it is helpful . Regards
