Previous Thread This topic has been viewed 8811 times and has 2 replies Next Thread
2CP
United States
6.2 Freezing when I try to Export to OBJ
I've done many successful exports of objects to OBJ format and then imported them to my library, but now, both before and after I upgraded to 6.2, When I hit Export to OBJ I get the first window, but it freezes before even showing the contents of the default folder.
I have to use Task Manager to exit from Java Binary in order to shut it down. It is happening on any floor plan, including a test one with just one object.
Running Windows 7 on a Dell Latitude 6520 with 8g memory and I updated Java.
Any ideas?
Much appreciated!
[Sep 9, 2019, 3:35:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 6.2 Freezing when I try to Export to OBJ
If this happens with any object you try to export, than most probably Windows is the cause of the problem.
Try to roll back the last update (or even two) and than test again.
[Sep 9, 2019, 10:44:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
2CP
United States
Thank you, Hans(?), it WAS a problem in Windows.
[Sep 10, 2019, 1:53:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
