6.2 Freezing when I try to Export to OBJ
This topic has been viewed 8812 times and has 2 replies
Thread status: Active
Discuss anything here [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Post Reply New Topic
2CP
Country: United States
Post by 2CP »
I've done many successful exports of objects to OBJ format and then imported them to my library, but now, both before and after I upgraded to 6.2, When I hit Export to OBJ I get the first window, but it freezes before even showing the contents of the default folder.
I have to use Task Manager to exit from Java Binary in order to shut it down. It is happening on any floor plan, including a test one with just one object.
Running Windows 7 on a Dell Latitude 6520 with 8g memory and I updated Java.
Any ideas?
Much appreciated!
User avatar
Country: Netherlands
Re: 6.2 Freezing when I try to Export to OBJ
Post by hansmex »
If this happens with any object you try to export, than most probably Windows is the cause of the problem.
Try to roll back the last update (or even two) and than test again.
2CP
Post by 2CP »
Thank you, Hans(?), it WAS a problem in Windows.
Who is online
