Total posts in this thread: 5
Previous Thread This topic has been viewed 2528 times and has 4 replies Next Thread
bbxrider
United States
no 3d in copy of drawing
I have a drawing where 3d works normal as expected,
made a copy, made some modifications to the copy and
can't get any 3d in the copy. I have moved the camera
to a different room in the copy, however even if put the camera
back in the same place as it was in the original I still
get no 3d in the copy
not sure what I should change in virtual visitor if anything
[Sep 11, 2019, 12:25:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: no 3d in copy of drawing
Did you check the coordinates of the virtual visitor with the visitor modification pane, after a double click on it? And does the 3D view work correctly in Aerial view mode?
[Sep 11, 2019, 1:36:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bbxrider
United States
ok, after closing doc and reopen it works, but don't know where are coordinates of virtual visitor? and don't know what is the visitor modification pane? I will check documentation and post back
[Sep 12, 2019, 7:16:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi bbxrider,
3D View > Modify virtual visitor
Have a good day.
[Sep 12, 2019, 9:53:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bbxrider
United States
thanks veroniQ, looks like you would some severe numbers in there to mess up the virtual viewer, like eyes elevation of like 40'
[Sep 12, 2019, 9:13:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
