Total posts in this thread: 4
Previous Thread This topic has been viewed 4349 times and has 3 replies Next Thread
ForlaniM
Italy
Render gives only black images
Hi all, i'm using the fere version to see how to renew my home.
I'm facing a strange problem:
On my PC (win 10 pro 64bit) using latest version (6.2 if i'm remembering well) every photo rendering gives black images (aerial or from view point), high or less quality.
I tried on another PC (win 10 pro 32bit, a little bit older, with less RAM and i had to use version 5.2 because newer versions can't work with G41 chipset): opening the same project renders well. I can't use this PC everytime i need because it's not at my home.
Any suggestion will be appreciated.
[Oct 23, 2019, 12:48:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Render gives only black images
If you send me your file, I'll have a look at it.
[Oct 23, 2019, 9:26:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ForlaniM
Italy
Sorry, i was away and i'm reading now your answer.
I've solved creating the project with the "older PC" and then opening at home.
So now i can work at home "on my home".
thanks anyway.
[Oct 29, 2019, 4:15:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LPQ
Argentina
Hi, since I installed the most recent version (6.2), I can't render again ... do you know why this is happening to me? Regards.
Leandro from Argentina.
[Nov 22, 2019, 11:54:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
