Previous Thread This topic has been viewed 8502 times and has 2 replies Next Thread
enkonyito
How to generate a .h file with javah?
In the YafarayRenderer.java file of the new plugin , there is the procedure to generate the YafarayRenderer.h file.
By replacing the initial packages with that of the PhotoVideoRendering plugin, I get this error message:
Error: Could not find class file for 'betaTest_plugin.YafarayRenderer'.
Enko
EnkoNyito
[Nov 10, 2019, 4:18:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to generate a .h file with javah?
To generate a .h file, you have to compile first the class which contains native methods, and add the path of the compiled class to the classpath used by javah.
Have a look to the comment of loadDLLs method in YafarayRenderer class to get more ideas.
[Nov 15, 2019, 5:38:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Thank you Emmanuel!
Based also on this documentation, I was able to generate the YafarayRenderer.h file in the plugin package.
/* DO NOT EDIT THIS FILE - it is machine generated */
#include <jni.h>
/* Header for class betaTestPlugin_YafarayRenderer */
#ifndef _Included_betaTestPlugin_YafarayRenderer
#define _Included_betaTestPlugin_YafarayRenderer
#ifdef __cplusplus
extern "C" {
#endif
* Class: betaTestPlugin_YafarayRenderer
* Method: createEnvironment
* Signature: (Ljava/lang/String;Ljava/lang/String;)J
JNIEXPORT jlong JNICALL Java_betaTestPlugin_YafarayRenderer_createEnvironment
(JNIEnv *, jobject, jstring, jstring);
Since I don't know JNI, generating DLLs is less obvious and I get an error in Eclipse when rendering.
It's easier with the modified YafaRay rendering plugin because I kept your packages and added the necessary files and folders.
EnkoNyito
[Nov 16, 2019, 1:51:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
