Previous Thread This topic has been viewed 1055 times and has 2 replies Next Thread
pjw359
United Kingdom
Can I superimpose one image on another?
I'd like to view a first and second image in respective levels superimposed, at the moment each image is a background image in a level but I can't see to view them together. My best work around is to superimpose the images using GIMP and then use a single combined usage ... but this is not ideal.
[Nov 25, 2019, 12:43:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can I superimpose one image on another?
There's only one background image per level as you noticed.
You could apply an image as a texture on the top of a thin box. This tip may give you also more ideas.
[Nov 25, 2019, 10:38:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DanielJ
Australia
Can we set macraces on this topic? I have a number of identical objects with different variables that will change slightly.
[Nov 26, 2019, 3:29:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
