(java:6708): dbind-WARNING **: Couldn't register with accessibility bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken. Exception in thread "AWT-EventQueue-1" javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D.createComponent3D(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D.access$200(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source) at javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:86) at javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:193) at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:180) at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:179) at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:179) at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:179) at java.awt.Component.processComponentEvent(Component.java:6371) at java.awt.Component.processEvent(Component.java:6319) at java.awt.Container.processEvent(Container.java:2239) at java.awt.Window.processEvent(Window.java:2025) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2297) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84) at java.awt.EventQueue$4.run(EventQueue.java:733) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.awt.EventQueue.dispatchEvent(EventQueue.java:730) at org.GNOME.Accessibility.AtkWrapper$5.dispatchEvent(AtkWrapper.java:700) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Exception in thread "AWT-EventQueue-1" javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment
Cette erreur ne semble pas bloquante au premier niveau (!) puisque l'ouverture de fichier 3D s'effectue et la visualisation également dans la fenêtre 3D. Je précise qu'il s'agit dune configuration double écrans avec second écran connecté en HDMI.
Comme indiqué dans un thread sur ce forum, j'ai également installé libqt4-opengl, mais le résultat est toujours une erreur au lancement.
Ma configuration est la suivante : ansible@solo:~$ uname -a Linux solo 4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u5 (2019-08-11) x86_64 GNU/Linux
ansible@solo:~$ cat /etc/debian_version 9.11
ansible@solo:~$ dpkg -l |grep sweethome3d ii sweethome3d 5.3+dfsg-2 all Interior 2D design application with 3D preview ii sweethome3d-furniture 1.6.2-1 all Interior 2D design application with 3D preview (additional furniture) ii sweethome3d-furniture-editor 1.20-1 all Sweet Home 3D Furniture Library Editor ii sweethome3d-furniture-nonfree 1.6.2-2 all Interior 2D design application with 3D preview (additional non-free furniture) ii sweethome3d-textures-editor 1.5-1 all Sweet Home 3D Textures Library Editor
ansible@solo:~$ dpkg -l |grep java ii ca-certificates-java 20170929~deb9u3 all Common CA certificates (JKS keystore) ii java-common 0.58+deb9u1 all Base package for Java runtimes ii java-wrappers 0.1.28 all wrappers for java executables ii javascript-common 11 all Base support for JavaScript library packages ii libapache-pom-java 10-2 all Maven metadata for all Apache Software projects ii libatk-wrapper-java 0.33.3-13+deb9u1 all ATK implementation for Java using JNI ii libatk-wrapper-java-jni:amd64 0.33.3-13+deb9u1 amd64 ATK implementation for Java using JNI (JNI bindings) ii libavalon-framework-java 4.2.0-9 all Common framework for Java server applications ii libbatik-java 1.8-4+deb9u1 all xml.apache.org SVG Library ii libbcmail-java 1.56-1+deb9u2 all Bouncy Castle generators/processors for S/MIME and CMS ii libbcpkix-java 1.56-1+deb9u2 all Bouncy Castle Java API for PKIX, CMS, EAC, TSP, PKCS, OCSP, CMP, and CRMF ii libbcprov-java 1.56-1+deb9u2 all Bouncy Castle Java Cryptographic Service Provider ii libbsf-java 1:2.4.0-5 all Bean Scripting Framework to support scripting languages in Java ii libcommons-io-java 2.5-1 all Common useful IO related classes ii libcommons-logging-java 1.2-1 all common wrapper interface for several logging APIs ii libcommons-parent-java 39-3 all Maven metadata for Apache Commons project ii libfontbox-java 1:1.8.12-1 all Java font library ii libfop-java 1:2.1-6 all XML formatter driven by XSL Formatting Objects (XSL-FO.) - libs ii libfreehep-export-java 2.1.1-3 all FreeHEP Export and Save As Library ii libfreehep-graphics2d-java 2.1.1-5 all FreeHEP 2D Graphics Library ii libfreehep-graphicsio-java 2.1.1-4 all FreeHEP GraphicsIO Base Library ii libfreehep-graphicsio-svg-java 2.1.1-4 all FreeHEP Scalable Vector Graphics Driver ii libfreehep-graphicsio-tests-java 2.1.1+dfsg1-4 all FreeHEP GraphicsIO Test Library ii libfreehep-io-java 2.0.2-5 all FreeHEP I/O library ii libfreehep-swing-java 2.0.3-4 all FreeHEP swing extensions ii libfreehep-util-java 2.0.2-6 all FreeHEP utility library ii libfreehep-xml-java 2.1.2+dfsg1-4 all FreeHEP XML Library ii libitext-java 2.1.7-11 all Java Library to create and manipulate PDF on the fly ii libjanino-java 2.7.0-2 all runtime compiler for Java expressions - library ii libjas-plotter-java 2.2.6+dfsg1-3 all JAS(2) Plotter graphic library ii libjava3d-java 1.5.2+dfsg-11 all Java 3D API (java library) ii libjava3d-jni 1.5.2+dfsg-11 amd64 Java3D API (java jni library) ii libjavascriptcoregtk-4.0-18:amd64 2.18.6-1~deb9u1 amd64 JavaScript engine library from WebKitGTK+ ii libjaxen-java 1.1.6-1 all Java XPath engine ii libjaxp1.3-java 1.3.05-2 all Java XML parser and transformer APIs (DOM, SAX, JAXP, TrAX) ii libjdom1-java 1.1.3-1 all lightweight and fast library using XML ii libjline-java 1.0-2 all Java library for handling console input ii libmail-java 1.5.6-2 all JavaMail API Reference Implementation ii libnb-org-openide-util-java 8.1+dfsg1-5 all Utility classes from the NetBeans Platform ii libnb-org-openide-util-lookup-java 8.1+dfsg1-5 all Utility lookup classes from the NetBeans Platform ii libreoffice-java-common 1:6.1.5-3+deb10u4~bpo9+1 all office productivity suite -- arch-independent Java support files ii librhino-java 1.7.7.1-1 all Libraries for rhino Java Script Engine ii libsaxon-java 1:6.5.5-10 all Saxon XSLT Processor ii libsunflow-java 0.07.2.svn396+dfsg-14 all rendering system for photo-realistic image synthesis ii libtablelayout-java 20090826-3 all Java layout manager for creating user interfaces fast and easy ii libvecmath-java 1.5.2-5 all javax.vecmath vector math package ii libxalan2-java 2.7.1-9 all XSL Transformations (XSLT) processor in Java ii libxerces2-java 2.11.0-7 all Validating XML parser for Java with DOM level 3 support ii libxml-commons-external-java 1.4.01-2 all XML Commons external code - DOM, SAX, and JAXP, etc ii libxml-commons-resolver1.1-java 1.2-7 all XML entity and URI resolver library ii libxmlgraphics-commons-java 2.1-2 all Reusable components used by Batik and FOP
Finalement, le problème est bloquant (!) Contrairement à ce que j'avais évoqué précédemment, après sauvegarde du dessin, puis réouverture, l'exception précédente est telle qu'il n'est pas possible d’afficher la fenêtre 3D.
Je suis preneur d'une solution .... javascript:smilie('') Cordialement
1. Sous linux OUBLIER LA VERSION DU REPOSITORY 2. Nous travaillons maintenant avec 6.2;(5.3 a 4 ans)
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
