Total posts in this thread: 6
Previous Thread This topic has been viewed 6297 times and has 5 replies Next Thread
mostafanasr
egypt
SAVING RENDER SETTINGS AUTOMATIC
When i try to render my sweethome 3d
i try different settings at Q3 and Q4
every time i save the resulted photo that is good
But i must record the settings every time even in photo name.
is there way to SAVING RENDER SETTINGS AUTOMATIC to return to it again.
thank you very much for this excellent application.
[Dec 29, 2019, 3:03:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Re: SAVING RENDER SETTINGS AUTOMATIC
Hi mostafa,
Whether with the AdvancedSettings_PhotoRendering-1.3.1 plug-in or the Rendering properties action of the PhotoVideoRendering-1.8 plug-in, the rendering settings of a project are saved after modification.
For a new project, the plug-ins find either the default values or the custom values in a file for the installer version of Sweet Home 3D.
You will find more information in this document.
Enko
EnkoNyito
[Dec 30, 2019, 9:27:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mostafanasr
egypt
Hi enkonyito,
first, thank you for your answer.
i need text file for render settings show me all settings i used for every render.
[Jan 4, 2020, 11:00:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
To know which file to edit according to your system, refer to this FAQ on increasing memory.
Regarding the rendering settings, just add -Dcom.eteks.sweethome3d.j3d.PhotoRenderer. in front of the properties of this file by modifying the default values.
(lowQuality: Q3; highQuality: Q4)
EnkoNyito
[Jan 4, 2020, 11:25:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mostafanasr
egypt
thanks enkonyito,
i will try it
[Jun 10, 2020, 6:09:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mostafanasr
egypt
thanks enkonyito,
i will try it
[Jun 10, 2020, 6:11:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
