Total posts in this thread: 6
Previous Thread This topic has been viewed 6424 times and has 5 replies Next Thread
ndorigatti
Italia
[HELP] Stainless Steel
I'm trying to create a cylinder (small, 5cm x 5cm x 5cm) that is made of stainless steel.
It should emulate glass holder for an intern staircase.
I tryed to download a blender object I found and export the material, but had no success (got a kind of white opaque item). I can search for the MTL file, but had no sense, it is obviously wrong (exported from blender).
Even making "Glossy" on the component it doesn't look Stainless Steel.
Have some of you a good MTL or some advice on how can I accomplish this?
Thank you very much!
[Jan 15, 2020, 1:02:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: [HELP] Stainless Steel
You can try this:
ChromeCylinder.zip
This cylinder has a mirror surface, and will produce a mirror effect.
Open the .obj-file in a text editor and search for usemtl There you can see what's creating the mirror effect.
Another way is to add a completely black colour and use shininess to create the effect. Works sometimes, depending on your render settings.
[Jan 15, 2020, 9:31:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ndorigatti
Italia
thank you cecilia! mtl file was close to mine, but yours work and mine not! i will try to understand what i did wrong, but for now works perfectly! thanks!!
[Jan 16, 2020, 6:37:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
the mirror effect is not created in the mtl , it's created in the obj -file.
You can open the obj -file in any text editor, same as with the mtl -file.
Then you will see what creates the mirror effect.
[Apr 14, 2020, 1:50:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AlbertKakiay
Indonesia
do you think ilum 3 and 8 in mtl are not applicable in SH3D?
Illum 3 or 8 for reflection and ray trace.
[Apr 26, 2020, 9:38:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As far as I have been able to understand, only illum 0, illum 1 and illum 2 are active with SH3D.
I have experimented with this program for years, so if you have a way to make illum 3 and 8 work, please share your secret.
[Apr 26, 2020, 4:44:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
