Previous Thread This topic has been viewed 3486 times and has 12 replies Next Thread
2manyprojects
US
Launch multiple instances of SweetHome3D?
I searched around and could not find an answer.
Is there a way to launch multiple instances of SweetHome3D?
I am using the linux version and launching SweetHome3D-Java3D-1_5_2.
Attempts so far to launch multiple instances, even from different source locations just shows the one currently running instance.
Thanks,
M-
[Feb 23, 2020, 6:09:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Launch multiple instances of SweetHome3D?
It’s not possible without dirty tricks, but I could add an option for that in a future version. Why do you need that?
[Feb 25, 2020, 6:07:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rrraf
I would also love that in order to be able to launch (night long) "multiple photo rendering" in multiple designs/files. Unless there's another way to achieve this?
Regards
[Mar 1, 2021, 12:26:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I added the com.eteks.sweethome3d.singleInstance system property in Sweet Home 3D 6.5 to make each launch of the application run in a separated process when set to false.
To use this property, add the line
-Dcom.eteks.sweethome3d.singleInstance=false
to a file named SweetHome3D.l4j.ini and stored in Sweet Home 3D installation folder.
[Mar 3, 2021, 6:55:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Would that enable us to use 2 instances of sunflow too?
[Mar 3, 2021, 10:07:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yes, but both instances will try to use all the cores of the CPU, so I’m not sure it will be efficient.
[Mar 3, 2021, 10:11:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The_Highlander
United Kingdom
I too would like to be able to run two instances of your excellent program but I cannot find any file named: "SweetHome3D.l4j.ini" in the Sweet Home 3D installation folder (or anywhere else on my computer).
I am running version 7.5 of the program on a Windows 10 PC.
Does the facility only exist for Linux users or can you tell me how to do it in Windows 10 please?
Thank you, &
Kind Regards.
There can be only one! 😊
[Jul 4, 2025, 1:12:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Just create the file SweetHome3D.l4j.ini in the same folder as SweetHome3D.exe
[Jul 4, 2025, 10:16:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The_Highlander
United Kingdom
Hoping that I had understood you correctly, I created a new text file (as shown below), renamed it as:"SweetHome3D.l4j.ini", opened it (with r/click > Edit ) and inserted the single line:-
"-Dcom.eteks.sweethome3d.singleInstance=false"
then saved it and moved it into the folder containing: "SweetHome3D.exe"
Having done that, I can, indeed, now open two instances of the program simultaneously!
Thank you so much for your help (and for your excellent program!). applause
Best Regards. biggrin
[Jul 4, 2025, 8:21:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Be aware that with separate instances you won't see a newly imported furniture or texture library in one instance in the other instance until you restart it. With a single instance setup you would see an imported library immediately in all open projects. In your case I don't think that will be a problem but remember it when you have two instances running for normal editing and you import furniture or textures.
Also understand that photo rendering will not be faster by doing it in two instances at the same time instead of one after the other. The only advantage is that you can start them both and let them run through the night.
[Jul 5, 2025, 8:48:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
