Total posts in this thread: 8
Previous Thread This topic has been viewed 5302 times and has 7 replies Next Thread
T3NZ3N
天下
Using SH3D Portable's Java Files to Run the TLE & FLE
In the documentation, I think it's mentioned that we can just run the TLE & FLE JARs from the Portable SH3D's own Java Files in it's own jre Directory.
I can't figure out how to set this up so I can run the TLE or FLE jar files from the files in the jre folder.
I'm running win10pro
The only executables with the java program Icon I found in the jre/windows/x64/jre8/bin were the javaw.exe
I tried simply dragging & dropping the jar to that and every other exe file in the bin, but nothing happened.
I currently have jportable in the Portable SH3D directory along with the Portable Launcher, but I'd like to try and see if there is a way to launch them directly without those, by using only the files in jre/windows/x64/jre8/bin
Additionally, I'm curious if the Portable SH3D Executable is just a Natively packaged Java File.
Thanks for any help
[Apr 25, 2020, 5:34:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Using SH3D Portable's Java Files to Run the TLE & FLE
The command to run a JAR file is:
path/to/java.exe -jar executable.jar
(you may also use javaw.exe)
[Apr 25, 2020, 5:40:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
T3NZ3N
天下
How can I add that to the launch parameters of the jar?
and will it be dynamic, if the drive letter changes?
[Apr 25, 2020, 5:42:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
T3NZ3N
天下
And when you say "I may use javaw.exe", what does that mean? How do I use it to make it do something.
[Apr 25, 2020, 5:43:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'm not sure you can change the launch parameters if java is not installed.
If you want to reuse the command you should rather store it in a .BAT file.
Simply replace java.exe by javaw.exe in the command I wrote.
[Apr 25, 2020, 5:55:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
T3NZ3N
天下
would the batch file just look like this?
"E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/jre/windows/x64/jre8/bin/java.exe" -jar "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/FurnitureLibraryEditor-1.25.jar"
that didn't work for me
[Apr 25, 2020, 6:03:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
T3NZ3N
天下
Except I used javaw.exe, as there is no java.exe in that folder
[Apr 25, 2020, 6:05:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
T3NZ3N
天下
Sorry, you need an edit button. The entire Bat file looked like this:
Run "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/jre/windows/x64/jre8/bin/javaw.exe" -jar "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/FurnitureLibraryEditor-1.25.jar"
[Apr 25, 2020, 6:07:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
