Total posts in this thread: 52
Posts: 52   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 262750 times and has 51 replies Next Thread
emirhanbskc
Türkiye
Re: Sweet Home 3D JS Online
Can we use Sweet Home 3D JS Online(not only viewer, I want to use with editor) own site ? Is it open-source. If okay. When I tried to deploy with ant, why only viewer libraries exporting
[Jun 13, 2021, 1:37:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SweetHome3DJS project is distributed under GNU General Public Licence so you can use it on your own site, as long as you respect the terms of that license, i.e. providing the source code of the modifications you may have made to the project for your needs.
Read project build.xml and you’ll see that there are other targets. I guess you look for applicationBuild target.
[Jun 13, 2021, 5:52:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
emirhanbskc
Türkiye
When I deploy with ant I get SweetHome3DJS-6.5.2-src\tools\JSweet\build\js\bundle.js file error (it doesn't create bundle.js file) and so I can't ant "applicationBuild" files.
[Jun 14, 2021, 3:52:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you read (and use) all the instructions in the README.TXT?
[Jun 14, 2021, 4:17:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
emirhanbskc
Türkiye
Yes, I did everything in the README.TXT in "Sweet Home 3D JS-6.5.2", I'm getting an error while ant.
[Jun 14, 2021, 5:26:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you install Node? What error do you exactly get (please do not copy all the log)?
[Jun 14, 2021, 5:56:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
emirhanbskc
Türkiye
Yes node is installed, when I run ant command in cmd
(BUILD FAILED
C:\Users\Emirhan\Desktop\Art²kAnd\SweetHome3DJS-6.5.2-src\build.xml:79: Warning: Could not find file C:\Users\Emirhan\Desktop\Art²kAnd\SweetHome3DJS-6.5.2-src\ tools\JSweet\build\js\bundle.js to copy.),I get the error.
[Jun 14, 2021, 6:15:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
emirhanbskc
Türkiye
I did not get any warning or error on transpiledLibraries section. Also I did not get error for j4ts-batik-svgpathparser-1.10.0-20170726/bundle.js, j4ts-swingundo-1.8.132-20170726/bundle.js and j4ts-awtgeom-1.8.132-20200519/bundle.js. They created but only tools/JSweet/build/js/bundle.js file not created. So ant says I can not move that file(tools/JSweet/build/js/bundle.js).
[Jun 14, 2021, 11:28:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The project was built under Mac OS X and can't be built under Windows and Linux at the moment. We'll hopefully fix that in a coming version.
[Jun 18, 2021, 11:15:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Finally, the error under Windows can be fixed easily: in build.xml Ant file, just replace colons (:) in the two following lines
<arg value="../SweetHome3D/src:tools/JSweet/src" />
<arg value="def:com/eteks/sweethome3d/model:com/eteks/sweethome3d/tools:com/eteks/sweethome3d/viewcontroller:com/eteks/sweethome3d/io" />
by ${path.separator} (see fix here).
By the way, if you want to generate SweetHome3DJS.war file, don't forget to run Ant default target in SweetHome3D project too. SweetHome3D.jar is required to generate the war file.
[Jun 18, 2021, 11:57:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
