Previous Thread This topic has been viewed 26758 times and has 10 replies Next Thread
Sweet Home 3D 6.4.2
For your information, I released tonight the version 6.4.2 which fixes a nasty regression which detached joined walls, when split with Plan > Split wall menu item or recomputed with room modification pane.
Please, update to this new version if you're using Sweet Home 3D 6.4.
By the way, I'm happy to announce that the 28th language supported in Sweet Home 3D will be Thai. The translation was performed by กันย์ชัชชัย โพธิหล้า (Kanchatchai Potila) and its SH3L file is available in Translations page. Many thanks for his contribution.
[Aug 8, 2020, 9:54:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sweet Home 3D 6.4.2
Working on both Windows and OSX, I have made the following Yafaray observations:
Windows seems to be a lot faster when rendering small and simple projects, while OSX seems to be much faster rendering more complex projects.
Opening SH3D on Windows also takes significantly longer than opening SH3D on OSX.
Any thoughts about this?
[Aug 9, 2020, 8:07:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your feedback smile
The changes I programmed mainly targeted the regression on some joined walls. There was a very small change in the way plan icons are computed but I don't see how it could have made Sweet Home 3D run faster.
[Aug 10, 2020, 7:57:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
After installing version 6.4.2 under Windows 10, Immunet gave me a virus warning. See screenshot.
Puybaret thinks it's a false positive, but maybe other users get the same message?
Problem is that I can't run this version, so I had to re-install version 6.4. Unfortunately that gives the same problem.
I'm investigating...
UPDATE
I uninstalled Immunet and installed Kaspersky. Problem solved!!
[Edit 3 times, last edit by hansmex at Aug 10, 2020, 12:10:02 PM]
[Aug 10, 2020, 9:12:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
None problem for me. applause
[Aug 10, 2020, 1:40:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry.
I have now tried some older versions on my Windows computer, and they behave just the same.
This obviously has nothing to do with 6.4.2.
[Aug 10, 2020, 5:44:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
1 ... i am still getting walls disconnecting at corners, but only 2 of them, they are not split. there are a total of 18 walls
2 ... the method plan > connect walls works on all walls but right click > join walls does not on the same 2 corners
this project has been saved numerous times.
using W7
[Aug 23, 2020, 9:35:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you check that the walls are drawn in the correct direction?
[Aug 23, 2020, 10:30:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yes m8. main point however is that i have to reconnect them every time i open the file
[Aug 23, 2020, 11:09:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It would be nice if you could send me a simplified version of your file showing this bug.
[Aug 23, 2020, 12:37:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
