Previous Thread This topic has been viewed 4082 times and has 2 replies Next Thread
Ruskinite_2
United States
Creating a simple 1" x 4" wall trim
Hi all -
Just bought SH3D and have been using it for a couple of days now, but I just can not find a way to add a simple [wood] trim (1" x 4" wall) to rooms that can be also used along the floors as baseboard (1" x 6").
I'd need to be able to adjust the trim's distance from the ceiling (i.e. dropped about a foot from the top) as well as adjusting the depth (i.e., how far it protrudes out from the wall). I would think that'd be a simple polygonal shape with parameter tweaks but I can't find that anywhere in the models or features. Here is the wood trim look I'm talking about...
Thanks!
[Jan 2, 2021, 7:35:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Shralen
Canada/Québec
Re: Creating a simple 1" x 4" wall trim
In your SH3D you should have a piece of furniture called Box, select that and drag it in your project. Then you can change the size and height to fit your room.
In case the image broke: https://sta.sh/01138nje06xy
For baseboard, click on the wall you want to add a baseboard, then go to 'modify baseboard' then modify as you'd like.
In case the image broke: https://sta.sh/025aj598pp2k
I'm more comfortable writing in English, but I can also write in French.
 ,___,
(OvO)   Hoot
 /)_)
[Jan 2, 2021, 8:41:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ruskinite_2
United States
Thank you!! Both suggestions worked!
[Jan 3, 2021, 10:31:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
